truck was running fine then turned a hard left to go up a hill and just shut off. Tried to restart and it tried to idle very poorly. Engine was shaking everything. then it was not even trying to fire. I don't believe it is a fuel problem as I have recently changed the fuel pump, filter, and pressure regulator. I recently contacted you guys about that fuel problem and after finding that my snap ring that holds the fuel pump had rusted out completely I got that resolved. ultimately it was actually a wire that was grounding out against the oil fill tube and cutting power off to the fuel pump. I don't believe it is the timing belt because I know what that sounds like from past experience. could a crankshaft or camshaft sensor just randomly quit working? I did let the clutch out fast shifting into 2nd gear because of the people tailgating me. any thoughts appreciated.
Jul 19, 2020 at 4:45 PM
