Truck has to be jump started everyday
2003 LINCOLN NAVIGATOR
155 MILES • 4.6L • V8 • 2WD • AUTOMATIC
DEXTER SANDERS
My truck runs fine, but when i park it for 8 hours or longer i have to jump start. It just recently started doing it everyday. It would only happen on the weekend when i wouldn't drive it for a day. Now it's happening daily.
Oct 18, 2019 at 11:29 AM
Welcome to 2CarPros.
It sounds like either the battery is weak or there is a parasitic draw. I am going to supply a few links to help you do some basic testing. The first link shows ow the do a basic load test. Do this when the battery is good and will restart the engine.
Before doing anything, make sure the battery terminals are both clean and tight. I have seen conditions where the jumper cables would tighten the terminal enough to allow it to start.
Next, here is the load test.
Here is the link to help find an electrical draw:
https://www.2carpros.com/articles/car-battery-dead-overnight
Here are a few links you may find helpful:
Let me know if any of this helps or if you have other questions.
Oct 18, 2019 at 9:09 PM
