truck 99 ranger problem please help asap
1999 FORD RANGER
289,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
DODGE287
hi i have a 1999 ford ranger 3.0 v6 flex fuel i have 2 codes p0171 and p0174
both banks to lean no i changed the maf sensor bought new one changed gas cap i smoked the truck to to see for vacume leak but nothing idk what it is please help
Jan 18, 2014 at 8:55 AM
SATURNTECH9
  • 30,869 POSTS
Where did you put the smoke in at ?What kind of smoke machine set up did you use?It wasnt a Halloween fogger was it?Sounds like a vacuum leak somewhere to me did you check fuel pressure yet?
Jan 18, 2014 at 9:18 AM
WRENCHTECH
  • 20,761 POSTS
Saturntech9 is correct here. I see these codes on Fords quite often and it's nearly always a bad vacuum leak, usually the PCV hose or large connector at the manifold.
Jan 18, 2014 at 9:54 AM
SATURNTECH9
  • 30,869 POSTS
Also the pcv grommets get worn and the pcv no longer stays in the valve cover.
Jan 18, 2014 at 11:06 AM
WRENCHTECH
  • 20,761 POSTS
They're biggest problem is the rubber deteriorates from the oil fumes and the vacuum will suck a hole right through the hose that may not be visible with the engine off. Listening is the best way to find it.
Jan 18, 2014 at 11:32 AM
SATURNTECH9
  • 30,869 POSTS
I like my homemade smoke machine I made with a old paint sprayer and glow plug.
Jan 18, 2014 at 12:14 PM
MAXIMILIAM
  • 436 POSTS
mi checked fuel pressure it was almost 30 psi.
Dodge287.
Jan 19, 2014 at 1:32 AM
WRENCHTECH
  • 20,761 POSTS
There is a major problem. The spec for this engine is 379bar (55 PSI).
You can finish here Louie. I just wanted to help you with the spec.
Jan 19, 2014 at 6:34 AM
ZALATOY
  • 4 POSTS
I have the same scenario! how did you solved your problem? please let me know...
thx
Nov 4, 2014 at 10:39 AM
ZALATOY
  • 4 POSTS
i have 99 ranger 6v 3.0 flex fuel same codes p0174 and p0171. i checked my pressure and it was around 33 psi. how did you solve your problem Dodge287? fuel pump or fuel injection damper?
Nov 4, 2014 at 10:45 AM
