Code p0011
2007 KIA SPORTAGE
124,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DIANA0313
Going down the road sometimes it seems to stall but doesn't. I fixed the solenoid about four months ago.have a code of p0011.
Jun 26, 2019 at 5:08 PM
Welcome to 2CarPros.
The code is related to the intake valve control solenoid. Is that what you replaced? It may be bad again. Here is a test to check it for operation without using a scanner. The attached pictures correlate with the directions.
_________________________________________
[Without Scan Tool]
1. Ignition "OFF".
2. Remove the intake valve control solenoid from the engine
3. Visually check the Spool Column of intake valve control solenoid for contamination
4. Connect 12V and a ground to 2 and 1 of the solenoid (Component side). Verify that spool column move to left as shown in the figure.
5. Disconnect 12V and verify that spool column move to original condition
Pic 1
6. Has a problem been found ?
- Repair or replace as necessary and go to "Verification of Vehicle Repair" procedure
- Go to next step as below
Check Intake Valve Control Solenoid Resistance
1. Ignition " OFF".
2. Disconnect intake valve control solenoid connector.
3. Measure resistance between terminals 1 and 2 of the CVVT oil control valve connector. (Component side)
A. Specification
pic 2
pic 3
4. Is resistance within the specification ?
YES
1) Go to next step as below.
NO
1) Replace the CVVT oil control valve and go to "Verification of Vehicle Repair" procedure.
Check the Suspected Area
1. Check the following items
- CVVT oil control valve filter for sticking or contamination
- Engine oil and it's level
- Engine oil filter
2. Is there any problem ?
YES
1) Repair or replace the CVVT oil control valve and go to "Verification of Vehicle Repair" procedure.
NO
1) Go to W/Harness Inspection - "Terminal and Connector Inspection" procedure.
I noted that you indicate little knowledge. Here are a few links that you may find helpful checking the solenoid:
Make sure the wiring is still tight and not corroded. Also, make sure the engine oil is clean and full.
Jun 28, 2019 at 7:01 PM
