Drove ten miles with no transmission oil
2000 TOYOTA TUNDRA
110,000 MILES • 2WD
Changed oil, drained transmission by mistake added 5 quarts oil anyway. started and drove 10 miles but with no transmission oil stayed in first gear. I think transmission is broken but what effect on engine.
Dec 1, 2019 at 10:06 AM
Good afternoon,
Yes, you most likely damaged the transmission and will have to be rebuilt.
As far as the engine, drain the oil and add the proper amount.
I bet it smokes a bit. I do not think you damaged the engine. The smoke will go away when all the oil is burned off.
Dec 1, 2019 at 10:40 AM
