The vehicle listed above will run on starting fluid. Replaced the fuel pump and filter. Spider injection, Crankshaft Position Sensor, MAP Sensor, Idle Control Valve. Injectors are getting the ground pulse to fire. 60 PSI fuel and will hold for days. The only time it ran on its own, we covered the throttle body as to choke it. It started and ran for 2 ten mile runs. Shut it off and it restarted a couple hours later. The next morning back to the same trouble. I'm stumped. The fuel out of the pressure gauge looks like foam. If I hold the release and crank the engine all of the fuel is like foam. If you let it sit it clears up. Stumped, never came across this before. Help. I have even got a re-flashed ECM.
Mar 31, 2021 at 9:59 AM
