Trouble with lock cylinder, Steering column/shifter won't go into park.
1995 CHEVROLET SILVERADO
150,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
STEVE FILCHAK
  • 5 POSTS
The actuating lever on the side of the transmission however will go into the park detent position. Where and why is it hanging up???? Is the problem with the lock cylinder/steering column, shift lever on the steering column/ shifter cable from the steering column to the A/T housing?
Feb 5, 2016 at 4:37 PM
HMAC300
  • 48,601 POSTS
from your question i'm thinking you can move the lever on trans to park but not by shifter. check for a broken cable then check shiftlock if on steering column.
Feb 5, 2016 at 4:45 PM
STEVE FILCHAK
  • 5 POSTS
If it's the cable, wouldn't it make the rest of the shifting positions in-op. The trucks driveable,it just won't go in park. Is the shiftlock tied into the faulty key cylinder lock? My friend told me he has trouble with the key turning the cylinder lock......
Feb 5, 2016 at 4:57 PM
HMAC300
  • 48,601 POSTS
the shift lock and faulty key cylinder are two different things. if it won't go into park the key won't lock correctly if at all. the cable may have stretched or is out of adjustment you have linkage i see so try to adjust it first and see if that is ok. it could be worn out as well
Feb 6, 2016 at 6:46 AM
STEVE FILCHAK
  • 5 POSTS
Thanks so much for the info HMAC300. The Low Rider GM owner will be happy the problem will be resolved. I'll let you know how I made out.
Feb 6, 2016 at 10:30 AM
