Having the ABS-anti- lock brake system light on means there is a diagnostic code or codes stored in your vehicles computer. The first thing you need to do is have the codes checked. Just be sure the scanner or code reader you use is ABS compatible to read ABS codes. Here is a tutorial showing what is involved with retrieving diagnostic codes from your car:
Once you perform this on your car get back to us with the code information and we can then properly diagnose your vehicle and send you tips on how to fix. Hope this helps and thanks for using 2CarPros.
Dec 18, 2020 at 11:19 AM
PARKERS GARAGE
MEMBER
Mice or animal chewed red wire going to ABS unit close to the weather pack connector and corrosion finished off the wire. Thanks
Dec 18, 2020 at 1:01 PM
DANNY L
CERTIFIED EXPERT
You're welcome!
Glad to hear you've found the problem. Let us know if you have any problems still after repairing the wire. Thanks again for using 2CarPros and hope you will use or site again in the future.
