Trouble codes after changing front manifold
2003 HYUNDAI SONATA
70,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
EDWARD HARTEN
Crank sensor wires had cracked insulation and shorted changed that and now getting codes p0335, p1505, p1507 and p0445. did I fry the ECM?
Jul 12, 2020 at 4:11 PM
P0335 - Crankshaft position sensor circuit malfunction
P0445 - EVAP Emission Control System Purge Valve Circuit Shorted
P1505 - Idle Charge Actuator Signal Low
P1507 - Idle Charge Actuator Signal Low
Based on what you are seeing these codes could be related. However, I would suggest you chase down the P0335 due to what you saw. I attached the wiring diagrams and testing for this code. Run through this and let me know what you find. Thanks
Jul 12, 2020 at 6:40 PM
