Trouble Codes
1999 JAGUAR VANDEN PLAS
129,000 MILES • 4.0L • V8 • RWD • AUTOMATIC
JEEPIN JIMMY
I am looking at buying the car listed above.
Vin#SAJKX6044XC862786 but it has a drivability problem in that it balks or hesitates on acceleration. It runs fine otherwise.
Trouble Codes are P0332 Knock Sensor Circuit Low Input Bank two.
P0332 code came up again.
P1111 No DTC Definition found see service manual.
Top reported fix:
Replaced Mass Air-flow sensor
Also reported fixes:
#1 Replaced engine.
#2 Replaced knock sensor.
Code 3-1 Replaced Engine.
Mar 2, 2017 at 7:41 AM
HMAC300
  • 48,601 POSTS
p1111 is a monitor type code meaning everything was not fixed after a drive. if the problem is fixed it won't come back on after erasing codes. for knock sensor it may not be getting good contact with block or over tightening it will ruin it. it can also be the wires are grounding out so the harness is replaced at same time as a lot of cars have a harness that connects to the knock sensors only. we do not list a resistance test for this for that year.
Mar 2, 2017 at 10:23 AM
