Welcome to 2CarPros.
The codes are identified as the following:
P0138 - Rear heated oxygen sensor bank 1
P0139 - Rear heated oxygen sensor bank 2
P0325 - Knock sensor
P0400 - EGR (exhaust gas re-circulation)
Can you explain what the vehicle is doing? Also, the o2 sensors can be off due to either the EGR or the knock sensor. I don't see how the EGR and knock sensor are related. The EGR valve could be bad or even have a vacuum leak or carbon build up. The knock sensor, on the other hand, is either bad or has a bad connection. It is located under the intake manifold and not a 5 minute job.
Let me know what you are experiencing so I can better diagnose.
Jul 31, 2019 at 7:48 PM
