Codes P0341, P0860 and P0107?
2004 CHEVROLET VENTURE
120,000 MILES • 3.0L • 2WD
PROJ6PI
Vehicle won't start or run. These codes showed up on the OBD scanner. Need help!!!!
Jan 6, 2025 at 4:14 PM
When you say the engine will not start or run do you mean it will not crank over, or it will crank over but not start.
P0341 - Camshaft Position Sensor Performance
P0860 - Transmission Control Module (TCM) Communication Error
P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Input
I would start by checking the fuses with the key on. This guide can help, I hope to find a blown fuse for the P0860 code.
Also, if the engine is cranking over and not starting have you tried starting fluid to see if the problem is fuel related?
This video should help:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
So, we need more information to help you. Please let us know what you find.
Jan 7, 2025 at 11:01 AM
AIDE ESPINO
I have a 2011 Jetta 2.0 it cranks but will not start. we found the timing belt was bad so fixed it, but still nothing and now codes say ECM and camshaft.
May 17, 2025 at 8:44 PM
This post is for a "2004 CHEVROLET VENTURE" can you please start a new question for your 2011 Jetta? Please post your new question here, you must be logged in.
May 18, 2025 at 5:35 PM
