Runs rough, will not go past 4,000 RPMs?
1996 MERCURY MYSTIQUE
120,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MOTZAMAN
Car starts and runs but has no power sounds rough and engine won't go over 4k RPMs. The only warning, I had that something was wrong was for about a week the car was idling a little rougher than normal and sometimes wasn't consistent. I've ordered an obd2 scanner that'll arrive tomorrow. I tried every method to manually get the fault codes, and none worked. Did the ignition/key method anywhere from 1 turns to 12 ending in the on position didn't work. Tried odometer method and nothing. So, I guess I have 2 questions here; how to get fault codes without scanner and does anyone have any ideas on what might be wrong with the car?
Jan 6, 2023 at 4:01 PM
You could have a simple cylinder misfire, but you must get a scanner to run the codes.
This guide will show you how once you get the scanner:
Please go over this guide as well:
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Please go over these guides and report back.
Jan 7, 2023 at 6:39 PM
MOTZAMAN
First effort at using obd2 reader was a bust. I bought a 2000 Taurus to get me back and forth to work $400.00 didn't come with a battery so took the battery from the Mystique found out that when you remove the battery all the fault codes reset including the stored ones. Tried to get it running but it was a very cold day and with its current problem it wasn't having it. Used the scanner on the Taurus it says air injectors are moving too much air. Car runs fine so in my completely amateur and nonprofessional opinion am going to ignore it.
Jan 8, 2023 at 7:07 PM
Okay, let me know if we can help with anything. Use 2CarPros anytime, we are here to help. Please tell a friend.
Jan 9, 2023 at 2:35 PM
