Hard to find transmission to replace model TZ1A4ZMFAA-M7
2004 SUBARU OUTBACK
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
JMHOOVER
MEMBER
1 POST
FOLLOW
tricky finding transmission to replace model TZ1A4ZMFAA-M7. is there a compatible unit, 2004 Subaru LL Bean H6 3.0?
Thanks
Jun 12, 2019 at 11:05 AM
KENW1
CERTIFIED EXPERT
Thanks for visiting 2carpros.com.
The TZ1A4ZMEAA will work from 03 models. Also the 2004 H6 4EAT can be used if you remove the tail shaft and swap the transfer duty solenoid and valve. You may want to try car-part.com for units. Below is a diagram.
