Treuing to find the right problem
2002 MERCURY MOUNTAINEER
179,530 MILES • 4.6L • V8 • 2WD
DRE827768
  • 10 POSTS
My ac is hot and there is green stuff leaking out in the bottom like in the middle when I looked down their it look like it was coming from a hose but not sure. When I was changing my spark plugs about 2 weeks ago I did notice oil leaking out of my #5 could it just be the intake or is it the a/c compressor
Jun 25, 2015 at 5:46 PM
ED-WEEZY21
  • 248 POSTS
If you have oil leaking out of your evaporator drain hose, you have a bad evaporator core. The oil in your #5 may be a bad tube seal gasket which is usually the only way oil can get in there aside from the actual valve cover or head being broken but that would be pretty apparent.
Jun 25, 2015 at 5:58 PM
DRE827768
  • 10 POSTS
What about the antifreeze leaking will that course it to leak?
Jun 25, 2015 at 6:44 PM
ED-WEEZY21
  • 248 POSTS
Not out of the evaporator drain. That drain is specifically for the evaporator due to the evaporator "sweating" and causes water to drip off of it and it needs to go somewhere. Same concept of a cold glass of water on a hot day and the outside of the cup starts to form water on the outside. Coolant would only drip from the heater core and if the heater core is dripping, its dripping directly onto the floor inside of your vehicle, not through the ac drain outside. I hope that clarifies it a little for you.
Jun 25, 2015 at 7:35 PM
DRE827768
  • 10 POSTS
Ok thank you
Jun 25, 2015 at 9:11 PM
ED-WEEZY21
  • 248 POSTS
Not a problem. Best of luck.
Jun 26, 2015 at 12:24 PM
