Bought truck with no keys so I had a roadside locksmith come out and make me a key. He made a plain key with no chips. truck started and ran for like thirty minutes but seemed like it was only firing on three - four cylinders. popped hood checked connections, oils, battery juice, belt tension, distributor cap, wires and wire seating, second turn of the key was about eight to ten seconds and it started up only with me fluttering the throttle and shut off. Third attempt until now only turns over and will not start. Disconnected fuel line and tested- 40+, air filter- good, tested spark-bad at coil under cap-replaced-entire distributor, spark plugs and wires. Spark retested-good, checked and tested fuses and relays. Still no start and no codes. Security light only flashes with key out. Key in, light goes out and stays out until removed-normal. Before replacing crank sensor I need to rule out a transponder key so I called a locale Nissan dealership and as soon as I said 1998 they confidently said no. "They did not put transponder keys or security systems in the 1998 or below Pathfinders only 1999 and up". So, I pulled up Google and call a few other locksmith services I get mixed answers about definitely no to some may have in 1998. My question is, does this seem like a key problem or something else?
Oct 2, 2018 at 6:56 PM
