The fuse powers a lot. Not just the transmission but the instruments as well.
DTC P0756
The code does not say "contaminated fluid" per se. Instead the code is most often caused by contaminants in the fluid blocking the valves from moving correctly.
From a TSB on it -
"The most likely cause is chips/debris plugging the filtered AFL oil at orifice number 29 on the top of the spacer plate. This is a very small hole and is easily plugged by a small amount of debris. It is important to remove the spacer plate and inspect orifice number 29 and the immediate area for the presence of chips/debris. Also, the transmission case passage directly above this orifice and the valve body passage directly below should be inspected and cleaned of any chips/debris."
That is why I suggested the flush, filter and fill. The flush may wash the crud out without needing to take the valve body out. It is an easy first test.
Aug 20, 2017 at 11:52 AM
