Transmission will not shift all the time
2001 OLDSMOBILE INTRIGUE
220,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
HUJKSER
My transmission wasn't really but I pulled up to a stop sign and stopped and my transmission disengaged and now it will randomly engage but when it does it shifts and only last for a matter of minutes.
Jan 7, 2019 at 9:08 AM
STEVE W.
  • 15,113 POSTS
Welcome to 2CarPros,
From your description I would start by checking the fluid level. Low fluid could cause this. If the fluid is clean and red with no grit and the level is okay then the next step would be to scan the transmission control module to see if there are any codes stored that could provide a direction of repair. If there are no codes then do a pressure test on the transmission to see if the internal pump is good. If the fluid and pressures check okay the transmission will likely need to be removed and checked for internal parts failure.
Jan 8, 2019 at 8:14 AM
