Put a new clutch in the truck and slave cylinder. I put it all back together the truck will go in gear, but it doesn't pull it won't move at all. It's like it's in neutral, you can put it in gear and take it out of gear when the truck is running or not running, and you don't have to use the clutch and when you put it in gear truck doesn't move or nothing.
Feb 24, 2022 at 5:15 PM
