Vehicle when put in drive or 3 position will not move but in 2 it will but is in limp mode because it stays in 2. It is rough when selecting reverse also but that is probably because of the high pressure when in limp mode. I have scanned it and fault codes p1137, p0141 (which relate to o2 sensor) and p0340 crank sensor. But i can't get any codes from the transmission control module and in fact i can't communicate with the transmission control module. But it should show a fault, i think. This just happened suddenly, and it was driving fine before that. Could it be a power supply to the module? Where is it located and how can i test it?
Your help would be appreciated.
Noel Begley.
Noel Begley.
Jan 24, 2022 at 3:34 AM
