Transmission wiring diagram needed please?
1999 FORD F-250
200,000 MILES • 7.3L • 4WD
MFITZGERALD
Needing to replace my neutral safety switch wiring and check wiring for whole transmission.
Apr 25, 2020 at 12:24 PM
I attached the wiring diagrams from Ford on the transmission. Let me know if you need more info and we can get it for you. Thanks
FYI - The neutral safety switch on an automatic is called a digital transmission range sensor. Others call it a transmission position switch or just a range sensor.
Apr 25, 2020 at 12:53 PM
FORDRIDINHIGH88
I have a 92 f-250 7.3L diesel and the wiring harness from the transmission somehow got wrapped around the axle and pulled some of the wires out of place. I can not find this particular wiring diagram anywhere is there any place that it can be located.
Thanks!
Jul 27, 2020 at 5:11 PM (Merged)
HMAC300
  • 48,601 POSTS
Here are the transmission wiring diagrams and a guide to help you test the connections.
J.STIEG
  • 361 POSTS
I am having some problems with my 92 ford truck I just put a transmission in it from a 94. I think the torque convertor lockes up right after I put it in gear. connectors fit but looked different. diagrams would help. thanks!
FIXITMR
  • 9,990 POSTS
do wire colors in plugs match?
J.STIEG
  • 361 POSTS
there are only wires on one side.
FIXITMR
  • 9,990 POSTS
and did you do any research as to interchangability before the swap?
FIXITMR
  • 9,990 POSTS
what motor is in it. it's 2 or 4wd?
J.STIEG
  • 361 POSTS
the salvage yard matched it up for me. It has a 5.0l engine. maybe the range sensor is messed up or the wrong one.
I just need a diagram so I can see what I have. Can you help?
J.STIEG
  • 361 POSTS
4wd as well.
FIXITMR
  • 9,990 POSTS
did you consider switching range sensors?
J.STIEG
  • 361 POSTS
Yes, I will call the salvage yard tomorrow to see if they still have it. the truck will barely take off
FIXITMR
  • 9,990 POSTS
does this help?
FIXITMR
  • 9,990 POSTS
that was 94 schematic, here is 92.
J.STIEG
  • 361 POSTS
I found out whats going on but not shure whats causing it. the engine is only running on 4 cylinders at times. The computers ground pulse is cutting out on cylinders 2, 3, 6, and 7. This is all happened when I put the transmission in. Truck runs bad now, Any ideas to further troubleshoot this problem?
J.STIEG
  • 361 POSTS
I forgot to mention that it was the fuel injectors that are not being driven by computer.
FIXITMR
  • 9,990 POSTS
those cylinders are ground bank #2 from computer the other 4 cylinders are bank 1. check output right at computer pin 69 (white wire) next to it is pin 68 (tan wire bank #1) if good wiring/connections are suspect.
