Transmission type and fluid capacity?
2010 SUZUKI SX4
28,972 MILES • 4 CYL • 4WD • AUTOMATIC
ANDRIN ATEM
  • 393 POSTS
JS2YA5A94A6300557
Hi, please can you help tell what type of transmission does this Suzuki uses, cat or ATF transmission? Secondly the fluid type and capacity it takes.
Thank you.
Oct 13, 2024 at 3:39 PM
Suzuki recommends using Suzuki ATF 3317, which is the recommended automatic transmission fluid (ATF) for this model.
You can also use a high-quality Dexron VI or equivalent ATF.
The automatic transmission typically holds around 7.4 to 7.6 quarts (7.0 to 7.2 liters) when completely dry.
For a drain and refill, it usually takes about 4 to 4.5 quarts (3.8 to 4.3 liters).
Let us know if you need anything else.
Oct 13, 2024 at 5:35 PM
ANDRIN ATEM
  • 393 POSTS
Thank you. Lastly how can I tell if the fluid level is on point?
Oct 14, 2024 at 12:53 AM
If the transmission does not have dip stick it will have a plug on the side of the case or the plug in the bottom which is a level tube where the fluid gets pumped in and then drains out to the correct level.
This guide should help you:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Oct 14, 2024 at 10:18 AM
