Transmission wiring?
2002 VOLKSWAGEN JETTA
135,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DSSM
Obd codes shows incorrect ratio for gears two and three. There is difficulty to get to gear two. I was told to change the neutral safety switch. I got a used one. Still gives problems unable to pass inspection. Help.
May 2, 2017 at 2:15 AM
There is a transmission speed sensor that goes out on these cars, here is a wiring diagram to show you which wires are going to it. I would try replacing the sensor and then clearing the codes. Check out the diagrams (Below). Please let us know what happens.
May 4, 2017 at 11:03 AM
