Can I put the transmission out of a 2012 Maxima in a 2015 Altima?
Oct 10, 2024 at 4:57 PM
CERTIFIED EXPERT
Swapping a transmission from a 2012 Nissan Maxima into a 2015 Nissan Altima may not be a straightforward process due to differences in the two vehicles. You will need to check the bolts patterns and the electrical connectors and torque converter size. If they are the same, you should be okay.
