Took transmission off to source an oil leak and when I buttoned everything back together my transmission is stuck in first gear. Clutch engages and disengages transmission like normal. I can get the shifter linkage into two spots (image 1,2). Me being retarded I originally put the linkage in upside down and tightened the torques bolts on top snugly it might of messed something up but I don’t hear any abnormal noises coming from the transmission. In image 1 the linkages looks as if it’s in neutral but does not move freely like it would in neutral. When I removed the transmission it was in first gear. Image 3 is an above view of the inside of the transmission with the linkage out. Really appreciate the help. thank you.
Apr 27, 2020 at 12:21 AM
