Good afternoon.
If you mean the speed sensor for the speedometer, it is located under the car where the right side axle goes into the trans-axle. It is held by a single bolt and a wire connector.
REMOVAL
1. Disconnect electrical connector from sensor.
2. Remove the sensor mounting bolt.
3. Lift the sensor out of the trans-axle extension housing. Ensure the 0-ring was removed with the sensor.
NOTE: The speed sensor gear meshes with a gear on the output shaft.
INSTALLATION
1. With 0-ring in place, install sensor and seat sensor by hand -- to ensure proper gear engagement.
2. Install mounting bolt and torque bolt to 2.2 Nm (20 in lb).
3. Connect electrical connector to sensor.
Feb 24, 2021 at 6:03 PM
