Transmission solenoid B removal
2002 HONDA ACCORD
21,200 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JAMESROWE
I'm trying to get transmission solenoid B out, but it is stuck and won't come out. Any suggestions would be appreciated.
Mar 29, 2022 at 6:19 PM
I attached the directions below. There are retainer bolts that need to be removed, so confirm they are out. If the solenoid still won't come out, gently wiggle it and twist it to see if you can loosen it. Chances are there is a build-up of corrosion causing it to stick.
Let me know if this helps.
See pics below.
Mar 30, 2022 at 9:07 PM
