It feels like my transmission is slipping when I first pull out of my drive way and give it a little gas. It has been cold where I live about twenty degrees F average. when the truck is cold the transmission will slip only once the rpm's spike a little and the truck jerks forward it only does it once when your first drive. After that it shifts fine. The fluid was low and I added a Quart of ATF +3 which is what Chrysler recommends. the fluid is now right in the middle of the okay marks. it is a four speed automatic transmission. any help to what this could be would be much appreciated.
Jan 10, 2018 at 12:37 PM
