I bought a new transmission online installed it and it gave me the engine code almost right away. is there something that could be causing this? I had to splice in a new wiring harness that plugs into the transmission. could a wire not connected right be causing this? I could take the transmission out and send it back, but that is a lot of work. if I could do something to figure out the problem it has. I will have the torque converter solenoid changed, if I know that is the problem. any help would be appreciated. also, it seems that when the car sits and I check transmission fluid it shows it is over full, but then when I start it up it sucks it down. I never heard of this. is this normal?
Oct 31, 2017 at 7:18 PM
