Everything seems to be fine except when I get to around 2000 rpm and I am in the throttle pretty good the rooms will jump up about 500 and it feels like the transmission is slipping. I have check the clutch fluid reservoir and it is full just checked the transmission fluid it is nice and red still and full. It just started doing it 2days ago. Any suggestions what might be causing it? A friend said the slave cylinder might be going out but not sure. I can grab the slave cylinder and it wiggles pretty good . Is that normal are should it be tight? Thanks Gavin
Jun 1, 2016 at 7:31 AM
