P1750 transmission solenoid assembly code. I guess from a little research, they are deep inside the transmission. You have to remove the pan, filter, and valve body to get to it. There is a ton of resistance tests you can do. To check each solenoid, but this does not look like an easy job by any means. I would erase the code and go for another test ride, I know you do not have OD, but see what codes come back. There also could be a problem in the harness between the TCM and transmission. I have found tons of corroded connections on the Eclipse that led me all over the place at times. Check circuits before tearing the transmission apart. I do not think the solenoids are very expensive, just hard to get to. Hope this helps some.
Sep 18, 2016 at 10:18 AM
