When shifting the engine/transmission jumps but not all the time
2008 PONTIAC G6
140,000 MILES • 4 CYL • AUTOMATIC
JOSEAVELAZQUEZ
Good morning.
My problems comes when I change from P to R or D the transmission or the engine jumps. The strange thing is that their is no check engine light. I already change all the transmission and engine mounts and still doing it. An important point is that it does not always do it. I wanted to know if it can be related to the input/output speed sensors and if yes where those sensors located at?
Apr 3, 2018 at 7:28 AM
Yes the sensors can be causing this. It would be better if you made a video and upload it so we can see what is going on when the engine jumps. I do not think a shaft speed sensor will make a difference when the car is not moving. We should run the codes even though the light is not on just to see if anything comes up.
Apr 4, 2018 at 11:18 AM
