Transmission Shifting into Overdrive
1998 CHEVROLET SUBURBAN
200,000 MILES • V8 • 2WD • AUTOMATIC
PEABODYVEE01
I recently had the intake manifold gasket replaced on my two wheel drive vehicle. Since that time it appears to have a transmission slip/clunk when it shifts into overdrive. Is it possible there could be a loose, disconnected or deteriorated vacuum line causing this issue? If so, where is the line located?
May 28, 2016 at 4:31 AM
HMAC300
  • 48,601 POSTS
the transmission uses no vacuum, but you could still have a vacuum leak. check hoses etc. Scan for codes auto parts stores does it for free. It may be a coincidental thing that has happened.
May 28, 2016 at 6:13 AM
PEABODYVEE01
Thank you!
May 28, 2016 at 9:50 AM
Here is a guide on how to check for a vacuum leak
https://youtu.be/xN5pcM-5bso
Let us know what you find
May 29, 2016 at 8:35 AM
