transmission shifting 1-3 without moving?
2005 MAZDA 3
25,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RENZ LAZER
When shifting to drive, the indicator shows rapid change from 1,2,3, but not moving and when it reaches 4 the transmission works but hard to get its power to move.
Oct 29, 2022 at 6:07 AM
It sounds like the transmission range sensor is not working correctly but to be sure we need to do a CAN scan which is easy to do. You can get a CAN scanner (Controller Area Network) from Amazon for about $36.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Amazon CAN scanner link for about $35.00.
https://amzn.to/3R9lJ60
Just us case I have provided the location of the sensor so you can check it out. Check out the images (below). Please let us know what happens.
Oct 30, 2022 at 3:29 PM
