Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chrysler
300
Drivetrain
Transmission
Symptoms
Not Shifting
transmission shift problem?
2007 CHRYSLER 300
260,000 MILES • 2WD • AUTOMATIC
TRAVIS COBLE
MEMBER
1 POST
FOLLOW
it will crank and run and will go into first gear but won't shift into any other gear.
Feb 18, 2023 at 2:23 AM
CERTIFIED EXPERT
This sounds like the TCM went out or the second gear shift solenoid is not working. We should run the codes to see what comes up.
Here is a guide to help us:
Is the speedometer working? The TCM is under the dash on the driver's side. Please check out the images below to see the location.
Feb 18, 2023 at 6:45 PM
