The TCC is located on the valve body, and it will have a LT/BLU wire going to it and it is possible the connection is no good which will cause the malfunction. I would check for power at the fuses in the wiring diagrams below, I have included the transmission wiring diagrams so you can see how the system works. You may have an IPDM going out if there is no power at the fuses.
Jun 24, 2023 at 11:16 AM
