Transmission release from clutch pressure plate
2007 FORD MUSTANG
120,000 MILES • 4.6L • V8 • 2WD • MANUAL
HECTOR RODRIGUEZ2
Have removed all parts/components in order to remove transmission/converter/bell housing/shifter/etc., from car, the output shaft sits on the teeth of pressure plate, half inch or less to fully drop, someone recommended loosing engine mounts and tilting engine a bit to allow transmission to drop. I have car on jack stands and I have enough clearance to fully wiggle transmission but not releasing.
Oct 9, 2018 at 5:26 PM
Good evening.
If I were you, I would get a floor jack and a block of wood. Set it up at the harmonic balancer and jack up the engine at the balancer. It should flex on the mounts and tilt the engine back enough for you to release the transmission.
Oct 9, 2018 at 5:41 PM
