Hi Tiffany, I just responded to the other post for replacement. LOL As far as a range sensor, the first indicators are usually the gear indicators are not operating or not correct. I mentioned in the post that if it doesn't show a P when in park and there are no lights on, the sensor is likely the cause. However, if it shows R (reverse) when you place it in park, it could be something as simple as adjusting the shift cable. I did indicate how on the other post as well.
Other symptoms can include the vehicle not starting, not shifting into the correct gear, the vehicle driving in what is called limp mode, and so on.
I hope this helps. Let me know if you have other questions.
May 10, 2021 at 4:13 PM
(Merged)
