When stopping will not shift out of overdrive
2009 CHRYSLER TOWN AND COUNTRY
128,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
DONALD TUSSINGER
Will not shift out of overdrive when you stop.
Jan 6, 2019 at 6:19 AM
Good morning,
Does the engine stall when you come to a stop? it should if it is stuck in overdrive.
https://www.2carpros.com/articles/automatic-transmission-problems
Are there any codes set?
How long since the fluid and filter has been changed?
Jan 6, 2019 at 6:39 AM
DONALD TUSSINGER
The filter was change 80,000 miles.
Jan 6, 2019 at 9:58 AM
Is that 80 ago? I see no mileage on the van listed here on the post.
Jan 6, 2019 at 10:11 AM
DONALD TUSSINGER
Car got 128,000 on it i had filter out in around 80,000.
Jan 6, 2019 at 10:57 AM
Got it, thanks.
I would still start there and check the filter.
Is the check engine light on? if it is, do you know the codes?
Jan 6, 2019 at 11:04 AM
