will not switch into higher gears. The odometer acts like the rpm gauge when at a stop. I replaced output sensor problem persist.
Apr 22, 2017 at 12:56 AM
HMAC300
CERTIFIED EXPERT
scan for codes first, but sounds like transmission is in limp mode. so may be the transmission has failed. best to have a transmission professional scan this for codes for a better diagnosis.
