Transmission not working properly
2009 CHEVROLET IMPALA
190 MILES • 3.9L • V6 • 2WD • AUTOMATIC
J REED
My car listed above (police) will crank up but seems like the transmission isn't engaging when changing gears. now reverse drive, just revs up and mph speedometer rises as well, but the car will not move . When changing the gear shifter from reverse to park it a grinding noise then goes away shortly after. any suggestions?
May 11, 2021 at 9:04 AM
It sounds like you have a broken axle or CV joint. Do me a favor. On a slope, place the vehicle in park and see if it drifts as if it's in neutral.
Here is a link that describes what I am referring to. If one side is no longer connected, this is what will happen.
https://www.2carpros.com/articles/how-a-cv-joint-works
Also, the idea that the speedo works and it grinds when placing it in park indicates everything is working but no longer attached at the wheels. The park test will tell me for sure if this is the issue.
Let me know what happens or if you have other questions.
Take care.
May 11, 2021 at 9:08 PM
