Transmission problem, car won't move in any forward gears, only reverse.
1992 FORD MUSTANG
170 MILES • 3.8L • V6 • RWD • AUTOMATIC
KIKIDOO
The car had been sitting for about a year and then I drove it for a half a day, the transmission seemed to be slipping. I checked the transmission fluid and the level didn't register on the dip stick. I went to drive it the following day and only moved in reverse. I put 5 quarts of transmission fluid in it, which brought it up to reading normal on the dip stick and still the same problem, only moves in reverse.
Mar 7, 2016 at 1:03 PM
HMAC300
  • 48,601 POSTS
Sounds like the transmission needs to be rebuilt or replaced, it could be a bad clutch or seal if it won't move. either forward or direct clutch pak.
Mar 7, 2016 at 4:07 PM
