transmission problem?
1996 PONTIAC BONNEVILLE
239,644 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CALI 1
It starts right up on park and on neutral but you put it on drive and reverse the car wont move. the e break is off if you put it on neutral and get out of the car and rock it back and forth eventually the car will roll then it goes into gears or if you just play with the gears from reverse to drive and rock it while shifting eventually the gears work. I have lifted the front and put the car on neutral and tuned the routers left and right eventually the car good into gear... please help solve the problem.
Oct 17, 2022 at 12:46 PM
Based on your description, it sounds like the shift linkage is loose or something is worn and not allowing the transmission to shift when there is pressure on it.
If I had to guess, I would think the shift lever nut on the transmission is loose. However, it could be any of the things related to it.
I attached a pic below and highlighted everything to check. When checking, first check for excessive play or looseness. If you don't see anything, with the engine off and the parking brake on, have a helper try shifting to see if something isn't fully moving or if one of the brackets is loose.
Let me know what you find.
See pic below.
Oct 17, 2022 at 6:55 PM
CALI 1
Thank you for the help. it works now it was one of the brackets wad loose.
Oct 19, 2022 at 10:05 AM
Thanks for letting me know. I'm glad you found the cause.
Please feel free to come back anytime in the future if you have questions. You are always welcome here.
Oct 19, 2022 at 6:37 PM
