Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Hyundai
Santa Fe
Drivetrain
Transmission
Reverse
Transmission only works in reverse
2006 HYUNDAI SANTA FE
70,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
TAGA
MEMBER
FOLLOW
The problem is it could go on revers but not on drive.
Sep 30, 2019 at 12:53 AM
CERTIFIED EXPERT
Good morning,
Is the check engine light on?
Did you check the fluid level?
https://www.2carpros.com/articles/automatic-transmission-problems
Sep 30, 2019 at 3:04 AM
TAGA
MEMBER
Engine light off fluid level okay.
Sep 30, 2019 at 3:36 AM
CERTIFIED EXPERT
Okay, thank you.
It sounds like you have an internal failure in the transmission such as clutch, drum or seals for forward application.
Looks like you will need a rebuild or replacing the transmission.
Sep 30, 2019 at 3:38 AM
TAGA
MEMBER
Thanks for the information.
Oct 3, 2019 at 4:34 PM
CERTIFIED EXPERT
You are welcome.
Always glad to help.
Oct 3, 2019 at 4:37 PM
