Transmission not working properly
2011 HONDA CIVIC
91,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ANDYBOY123
  • 5 POSTS
The other day was driving on the freeway about 75 MPH then all the sudden the car felt like it slammed on the brakes on its own and actually engine sounded like as if downshifted into first but it was in D4. it’s a automatic transmission after it happen hit the brakes then gas again then it went back to normal.
second time it has happened. could it be the shift solenoid???
Jun 21, 2021 at 10:01 AM
We should run the codes this guide can help, but it sounds like you have a fluid pressure sensor that is going out. here is the location in the diagrams below to help you fix it car:
Jun 22, 2021 at 10:22 AM
ANDYBOY123
  • 5 POSTS
Okay, so best bet is to replace both of them. I believe it has 2 top and bottom.
Jun 22, 2021 at 11:25 AM
That would be your best bet. Let me know what happens.
Jun 24, 2021 at 10:56 AM
