Car listed above is the CXL model.
At around 75,000 a issue started with transmission. When starting car and driving out of the driveway or wherever i am driving my car will shift normally from 1 to 2 gear. Then it will shift from 2 gear to 3 gear and slip back down to second gear. Normally only do it when first riding then after a few miles it will switch through all gears normally. I have been doing some playing around with and and figured if i run it to a higher RPM when on 2 gear to 3 gear the transmission will go smoothly to 3 gear and 4,5,6 . But when i drive the car at a lower rpm like typical cruise acceleration the car will make it to 3rd gear and slip back down to 2 gear. I have had a transmission flush and that didn’t help problem still occurring .
Oct 10, 2019 at 7:48 PM
