It sounds like the transmission is going bad but I would try to replace the engine coolant temperature sensor which could be shorting out when warm causing the issue.
Here is a guide to walk you through the steps and diagrams below to show you how on your car:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Check out the diagrams (below). Please let us know what you find.
Oct 11, 2018 at 3:49 PM
