Transmission problem
2005 VOLKSWAGEN BORA
90,000 MILES • 1.6L • 4 CYL • FWD • AUTOMATIC
EDBUCH
  • 4 POSTS
I recently serviced my gear with the right transmission oil and filter. After the servicing, the engine shuts down whenever I engage the gear. What could be the problem?
Sep 14, 2016 at 2:24 AM
It sounds like you have one of two problems that has happened, either the TCC solenoid is stuck on or the torque converter has failing apart and needs replacement.
Please let us know what you find so it will help others.
Best, Ken
Sep 17, 2016 at 6:56 PM
EDBUCH
  • 4 POSTS
What is the other name for TCC Solenoid?
Sep 20, 2016 at 3:51 AM
Torque converter clutch control solenoid. Do you have the correct fluid in the transmission, those cars take a special kind.
Sep 20, 2016 at 10:59 AM
EDBUCH
  • 4 POSTS
What kind of transmission fluid is required for the model of my car?
Sep 21, 2016 at 1:58 AM
EDBUCH
  • 4 POSTS
No, I used a particular one I have been using since I got my car and it has never given a problem. The problem now is my mechanic doesn't know what TCC solenoid is, maybe he knows it by another name. Can u help in telling us where it is located ? Maybe this can help.
Sep 22, 2016 at 4:59 AM
It is one of the solenoids inside the valve body my information does not tell me which one it is unfortunately.
Sep 22, 2016 at 10:38 AM
