Quick note: the transmission oil with filters were replaced 8 months ago with recommended ATF+4 trans fluid.
Only while idling in Drive the message Transmission Over Temp appears with fans turning on but switching to neutral gear while at the lights or a drive-thru the 'Transmission Over Temp' nor fans do not come on.
After reading similar issues, I understand this may be due to either the battery or starter wires and of course, a transmission temperature sensor issue? thank you in advance.
Jun 15, 2020 at 4:59 PM
