Transmission output shaft?
2000 HOLDEN STATESMAN
250 MILES • 5.7L • V8 • 2WD • AUTOMATIC
GDURB
Should my transmission output shaft have any movement in and out of transmission.
Jan 7, 2024 at 6:05 PM
Please understand this vehicle isn't offered in the US, but I will try my best to help.
As far as your concern, generally speaking, there can be a small amount of movement or play in the transmission output shaft due to acceptable tolerances in the gears, bushings, and bearings. However, excessive movement or wobbling isn't normal.
In many cases, output shaft endplay between 0.005 to 0.025 inches (5 to 25 thousandths of an inch or 0.13 to 0.51 millimeters) is normal. However, these measurements can differ significantly between various transmission types and models.
Let me know if that helps.
Jan 7, 2024 at 7:27 PM
